I've seen someone pull the dimensional data out of the applicable aircraft model from a flight simulator software program. It obviously wasn't "CAD" data, but it did have all the dimensions to a reasonable degree of accuracy. It took some serious spreadsheet slogging to format it for the intended (mis)application.
Thank you for a quick response (hookie66).
This is a personal project.
Most of home built simulators that are out there
are not accurate designs depictions...
Thank you MikeTheEngineer,
If Boeing will give or will not, I have no idea at this point though I did notice
a link on Boeings site (Licensing Boeing Digital Information) something worth trying.
Thank you IRStuff for you response,
but unfortunately the information that's probably available for Microsoft's flight simulator, or X-Plane
is not what my question is about.
Thanks VEIBLL you're proposing reverse engineering,
But I do'not want to go that route, besides it's easier to just eyeball from ddetailed photos
readilly available.
