In 2000, the committee added a detailed section on uncertainty. The outcome of that was that Beta ratio needs to be between 0.32 and 0.70. For a 4-inch tube 0.32 beta is 1.280, so call it 1.250 and accept 0.31 Beta. At 100 psia and 100 [°]F, 50 MCF/d is 0.3 inH20. Since most of these 4-inch tubes are calibrated 0-150 inH20 (standards again) a 0.1% uncertainty is +/-1.5 inH20--at 50 MCF/d you have numbers that have little to do with measured volumes. At 112 MCF/d (1.5 inH20 at 100 psia in a 4-inch tube with a 1.25 plate)you know that you are between zero and 159 MCF/d.
I haven't looked at the graph in a while, but I seem to recall that a 0.625 plate in a 4-inch meter (0.155 beta) would have an uncertainty greater than 4%.
David
David
