hello all,
I want to calculate wall thickness of 70/30 Cu-Ni (B466) pipe.
I am using the formula that is from B31.3 para 304.1.1. Is the procedure same as carbon steels.
Should I add corrosion allowance to pressure design thickness, or assume CA as zero?.
Finally are the wall thicknesses of the different schedules are as same as for the carbon steels.
thanks in advance.
best regards
prens
thanks in advance.
best regards
prens
