Guest102023
Materials
I am looking at some 16" diameter Alloy 20 piping that is experiencing fairly rapid corrosion in a pH3 environment @ 300°F, with unavoidable deposits settling on the bottom. There is pitting in the vapour space and more general (at least smoother) corrosion on the bottom side under the deposit. I am looking at the 6% Mo stainlesses, as well as Hastelloy C-276. How do these alloys rank in these conditions?
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
