5th axis required? 1
pedrof
56
I require 2 flat surfaces parallel to each other to be milled, with a straight sloped surface i.e. a long chamfer connecting the 2 planes. The surface finish is not critical on the sloped section and I can live with rads on the 2 corners. One machinist tells me this requires 5th axis, another doesn't. I would have though as long as the path of the tool is in straight line that this could be done without the need for a 5th axis machine. I've attached a sketch to illustrate the profile side on.
Just want to clarify if this does need 5th axis or not.
Does not require a 5th axis if you machine it with the top view being just as you have it sketched. You will get a radius (1/2 tool diameter) where it transitions from the angled slope to the flat again (inside corner only).
You could also machine it on a CNC mill. It will take some time to get a smooth surface but it can be done.
Thanks for those responses. I just want to make sure I've explained this correctly. I think the pdf may have been 90° out.
Here's a pdf of a 3d model showing a tool and the blue faces are those to be machined, this is just indicative, I appreciate the tool is not very realistic.
 http://files.engineering.com/getfile.aspx?folder=09ec12f0-3ebc-4f1b-af0e-6a94e3222c6b&file=test1.pdf
Autodesk Inventor right?
Why not machine it with the tool in the red axis (x axis)?
Doing it the way you have it you will have a wierd radius on the inner edge of the sloped face.
Sorry, should have clarified. The milling has to be from the direction shown due to other features on the part not shown here. I think we could live with that 'wierd' radius as long as it's not too large. We have sheet metal which needs to have a lip to mount against, so we can cut this back to make sure it's meeting a flat surface i.e. missing the 'weird rad'. I guess overall it looks like it can be done without bothering with going to 5th axis but with some caveats..(...and yes, it is Inventor). I'm getting the 'can-do' machine shop to mill me a sample block so I can get a feel for surface finish etc.
Surface finish should be fine if its just mating a sheet metal part on to it.. And that "wierd" radius can be made really small by simply making a second run through that radius with the smallest end mill they can.
Obviously if this is a 1 off there is no issues. But I would actually suggest them making the part in 2 steps if this is a production part. Run your top features, then turn the part. I bet it's faster n 2 steps depending on what you can live with as far as surface finish on the sloped plane.
If their CNC machine can actually turn the part (typically called an A axis I believe) during machining your even better.
A drawing in one plane is not helpful at all.
Dicer,
.......which is exactly why I posted a 3d view with a mocked up cutter further down, see link above.
To clarify you original question, "NO" you do not need a fifth axis to machine this. You do need a fourth axis however so you can rotate the part to the proper angles for machining the flat surfaces. Are you planning to machine this in house?
Larry
