Multi-Core Processors
  • Thread starter Thread starter Borisw37
  • Start date Start date
B
Borisw37
Guest
Does Pro/E take advantage of multi core processors?
What would run better a 3.0ghz dual core or 2.4ghz quad core, everything else being the same.
You are better off with the 3 GHz dual core unless you are running Mechanica. Even with Mechanica you might still be better off with the 3 GHz dual core. The hardware is getting ahead of the software's ability to take advantage of the multiple cores.
