Thank you for the info.
Are you sure this mil-spec will have the elongation of 52100 tempered at 300F,400F,500F,600F,700F,800F,900F,1000F?
52100 is not usually considered for use in aerospace applications except as bearings with hardness over 60 HRC.
Heat Treater's Guide and Vol 4 contain ductility/elongation data on steels like 4140 and 4340, but not 52100. Since the m/s is carbide in tempered martensite, how is ductility affected? Is there a sudden increase when tempered at 700-750F?
