Suggestion to skogsgurra (Electrical) Oct 14, 2003
The fact that you do have a single phase motor complicates things a little.
///It may if not desiged for 50Hz and 60Hz.\\ Going from 50 Hz to 60 Hz will change the impedance of the start/help winding upwards and reduce the capacitor impedance.
///This is very trivial since
Xc=1/(2xpixfxC)
appears even in technicians and electricians textbooks.\\ That means that the phase-shift in the start/help winding is reduced and can reduce the torque so the motor won't start. Reducing the capacitor value about 20 percent could help (same impedance as before, motor winding impedance still on the high side).
///Yes, visit
for the single phase permanent-split capacitor motor.\\You should also bear in mind that the motor needs 20 percent more voltage at 60 Hz. Running at 220 or 110 V will increase the slip and that means a hotter as well as a weaker motor.
Adding 20 percent (60 Hz is 20 percent more than 50 Hz) to 110 V will give you 132 V and I think that 120 V could work. If you have acess to 277, I think that it would be even better since it is close to 220 + 20 percent, which is 264 V. The latter voltage is a far better match for the 220 V winding than is 120 V for the 110 V winding.
///If motor is not designed for 60Hz, the higher voltage will have impact on the motor aging.\\Also, do not expect sychronous speed like 1800 or 3600 RPM, but that you already knew.
