50 Bar Piston O-ring shore hardness
Poorpaulus
Automotive
GB
Hi everyone,
I'm working a piston that will see about 50 bar, but will also see approx 1 bar vacuum. It has a stroke of only 25mm, a 18mm dia and a linear speed of only 2mm/sec. This change from pressure to vacuum will occur over a matter of just a few seconds.
I've been asked by the Chief Engineer to investigate if there's any advantage to increasing the shore hardness of the o-ring from 70 to 90. His concern is that the "shock" of the sudden change from pressure to vacuum will have an effect on the o-ring, causing it to fail.
Any thoughts on this would be appreciated.
Is this a new design or adapted from another mature and successful product?
Regardless, I'd study the Parker Handbook ( available to download online), and then talk to the folks at Parker.
I think you will find that 50 bar/750 psi is nominally well within the range for O-ring sealing.
Details like backer rings or the gap between components to prevent the o-ring from extruding into the gap are important.
Will the poor o-ring being asked to slide while managing 700 psi?
I think I'd want some lubrication if I were that o-ring.
It is a variation of a legacy design which has worked for years. I thought that the question concerning shore hardness was a valid one, but I can't find any information concerning my original question.
You might consider a quad ring seal in 70 durometer. Less likely to spiral fail.
Ted
My first thought is that the seal could suffer RGD damage from the rapid pressure swing, however that will be highly dependent on the process media/temperature and o-ring compound.
For the sake of the cost of an o-ring, I'd probably go with the harder duro, or preferably an RGD resistant compound.
Note that there will be an increase in stiction going to a higher duro o-ring, going with hydtools suggestion of a quad ring will help negate this and as he mentioned reduce the likelihood of roll fail.
Thanks for your thoughts, everyone. Most informative.
