5 axis machining
kaizad
I have experience with 3 axis CNC programming and would like to expand the knowledge to 5 axis programming. I have access to Catia V5 and UG NX4 manufacturing modules. Are there any sources available for tutorials that could be useful (or even books to help in learning)?
Thanks.
If you want to learn how to use either the CATIA or UG....here is an affordable source.
As far as learning 5 axis programming, well my friend, you just have to do it.
Working for a shop that actually has a 5 axis helps.
Good luck.
UG has a tutorial called CAST. It is an awesome way to learn.
-Derek
