ThirdString
- Apr 21, 2005
- 36
I am looking for a material that would be used as a diapragm that is expanded by pumping hydraulic fluid into it. Working pressure can be as low as 5k psi, but 10k is more desirable. And, being a diapragm, it needs some flexibility to collapse when it is not pressurized. If I have a starting point I should be able to figure out the specifics from there. Thanks!
