450 - 470 MHz Radio Transmission Indiana US
FlightSim
GB
Hi, could some one advice on wha the requirments for transmitting on UHF 2 450 - 470 MHz for Indiana US. Whats the power limit before a license is required. Is there a specific band width to use 12.5 or 25KHz. Thanks Paul
In the USA, this is totally regulated by the Federal Communications Commission. The states have nothing to say about it. Check the listings here:
You will then need to review the license requirements and restrictions for the various services listed.
I've registered and received an FRN applied under as a Foregn Entity.
For 450-455MHz is says Fixed Mobile for the Radio frequency Spectrum allocation would that cover transmission of RTK corrections for from a fixed base for conducting a survey? I'm trying to select the service option for a new FCC license application but am unsure as to which service option this comes under, I was considering using around 453 MHz if possible for transmission. Thanks Paul
