Looking at using 440C or 420HC for an application of sleeve and bushing on a large universal joint for a bottom drive auger in an abrasive application. Sleeve is press fit onto the cross, bushing is stationary in the yoke. RPM is about 30 rpm, motion is a 15 degree back and forth rotation. Which material is best to prevent galling, should I mix the two, one for the shaft one for the bushing, what rockwell difference is best, and what finish profile is recommended.
