I've got a new sludge press which requires a wash water connection. Normally the press will use the plant's non-potable water supply. However, I've also provided a potable water connection should the non-potable supply fail due to pumps, plant upset, etc. I have an RPZ installed on the potable side of the connection. I was told I need a "4-way valve" which will only allow one feed or the other to be connected to the press.
I'm not arguing this is a bad idea at all, but the plumber who is telling me this dosnt know where in the code it says it's required, and for my own info I'd like to know where I can find it in print. Anyone know?
Thanks,
Mike
Thanks,
Mike
