I'm looking to drive a toy train from the analog 4-20 of a slc 500.. So I'm not sure on how to convert 4-20 to 0-12vdc with a 1A load capability. Is there a product out there that will do this? I use I/P at work all the time, but I can't find an I/E in any of our catelogs that will drive that much load. I also thought about using a 0-5VDC card to drive the base of a power NPN transister with 12VDC feeding the collector. If I use the Emitter of the transistor to drive the load will I get a linear drove from 12 to 0 or will it act like an on off switch?
