We have to commission a Crude Oil Pump which will be driven by a 3000 kW, 11kV Motor. The motor is having an Ex "d" enclosure suitable for Hazardous area. Physically the motor is very large due to the Ex "d" enclosure.
The subject motor is totally enclosed, fan cooled (Air cooled type IEC IC-511). But the bearings are forced oil lubricated. The lube oil pump is electric motor driven and is common for pump and motor bearing lubrication.
Now, the motor is ready for No-Load Trail, but the Lube oil pump is not yet ready. How to take the motor No-Load trail?
The vendor says, the three (3) hour No-Load trail (de-coupled from the pump) is not necessary. Only the kick start to check the direction of rotation is sufficient.
Any experience to share or any views?
I personally feel that the motor no load trail for three (3) hours shall be performed before giving clearance for the coupling.
