I don't know if this will be helpful to anyone, but I wanted to share this with all of you.
I was reading back through thread559-189982 and decided to investigate 3GB switch again.
I started reading up on just about all the 3GB articles I could find. I read Ed Eaton's and Wayne Tiffany's articles on the 3GB switch along with Microsoft's info. but Wayne Tiffany showed me the most of what can be done.
thread559-155411
Other articles I found:
On my system I have just 3GB of RAM. But XP of course could only use 2GB still. I initially used the MS line for the 3GB switch and I have to say it ran like crap... it was slower, SW was slower it was ridiculous. So I went back to just the readable 2GB. I had not pursued it further until this morning. I am still testing, but I found an option that seems to have worked.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional 3GB Limited" /fastdetect /3GB /userva=2000
This one worked for me. I have other bootable lines, but this one works and the memory allocation is actually better then it was before. I don’t have an AV on my system and that does allow for less memory to be taken away from Windows and SW. Which is why I don’t want an AV, I will take my chances. I now have Outlook open along with IE, Mozilla (4 tabs), SW (complex assembly opened), Word, 2 windows Explorers, Task manager and my boot.ini file opened. I am approximately using just around a single GB of memory. I have a total of 36 processes running along with my PDMworks services running on this machine.
I have to say I am very impressed as before I would be running a higher amount of memory and running slower.
But this is just how my system is reacting to these changes. Your Mileage may vary... so if you decide to pursue the 3GB switch I recommend those articles and any others you can find online. Then try it out on your system as long as you keep your default boot, you should not have to worry about not getting back into windows.
Scott Baugh, CSWP![[pc2] [pc2] [pc2]](/data/assets/smilies/pc2.gif)
"If it's not broke, Don't fix it!"
faq731-376
thread559-155411
[boot loader]
timeout=30
[operating systems]
![[cheers] [cheers] [cheers]](/data/assets/smilies/cheers.gif)
Scott Baugh, CSWP
faq731-376
