3D x,y,z data import
stimpee
Is it possible to import a 3D point "cloud" into solidworks? I initially want to only be able to visualize the data, but I would eventually like to be able to fit surfaces to the points and then ultimately build solids using those surfaces.
Anybody have any ideas?
Steve
Hi Stimpee,
I developed a macro that do this kind of thing. But this API tool isn´t generic, it works just with some kind of digitalized files. I developed it for a SW Client, once I work for a SW reseller.
Just to help you... could you send me the digitalized file??
I hope it can helps.
MHendler
MHendler,
Send me your email address and I will send you a file. I have a few different purposes for needing this capability. One is for visualization only. The more complex one is for taking a point cloud and fitting a surface to it.
Stoker, I checked out ShapeWorks and while it looks quite cool, they say the capability to import "cloud of points" data is "coming soon"!!!
Thanks,
Steve
From the SW website, there is an application available for download from the Model Library. Sign in as if you were downloading a SP, then pick the Model Library from the menu on the left. Check the API section and look in the Modeling Utilities under the VB Examples. Here is their description:
Point Cloud from File - This macro/script reads in a table of xyz points from a space, tab, or comma delimited txt file and plots the points into one 3D sketch. It could also be used to create a 3D spline.
Note, access to this requires subscription support.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
