J
Jevnydaniel
Guest
I always think CNC Machining is the better way for many of our customer’s project,because many advantages like below:
*Speed — Get CNC machined parts at least as fast as you can get additive rapid prototypes.
*Convenience — Firstcut brings the online quoting and ordering you expect from rapid prototyping to the CNC machining world.
*Real material properties — Your parts are machined from real blocks of plastic and aluminum — not the “material like” materials used in additive rapid prototyping processes.
*Improved surface finishes — CNC machining eliminates the stair stepping inherent in the additive processes.
Daniel.lou@jevny.com(Work for Jevny Technology)
