Aug 12, 2009 #1 D design-engine Guest Anyone got a clue how to adjust the spin center for a 3d PDF before or after exporting from Pro/ENGINEER.
Aug 20, 2009 Thread starter #2 O orac Guest This can be easily done within Acrobat Reader (minimum version required is 9) after you have opened the 3D PDF. Click on the image in Acrobat Reader and press the button with the camera icon on top of the screen. A dialog window appears Enable "alignment - target" and press the button "Select Model". Now click somewhere on the model you want to rotate. After you have done this, press the left mouse button and keep it down to rotate your model. Hope this helps. John Bijnens http://cad2cam.khlim.be
Feb 12, 2014 Thread starter #3 P pspreier Guest Check out this blog post for more information: How to set the center of rotation when viewing a 3D PDF file
