3D charts
Tmoose
I'm an Excel novice.
I have velocity and mass flow data taken across various sections of pipes.
I'd like to chart the results with a bar graph with the X axis wound into a circle.
I've Searched for Excel plug-ins and stand-alone free/shareware/commercial software to accomplish this with no success. I found plenty of programs to make bars of stacked footballs, fish or clown heads.
My best solution to date is make parametric CAD model with blocks in a circular array and extrude the block heights proportional to the test values. It's actually pretty quick.
Am I overlooking a simpler solution?
thanks,
Dan T
You could do something similar with VBA to manipulate autoshapes.
I think it would be cumbersome.
You might just consider using the surface chart.
Convert your radial coordinates to (X,Y)s
Place the Xs as column headers, the Y as row headers and the velocity values in the corresponding cells.
Plot using the standard surface chart.
"I think it would be a good idea."
- Mahatma Gandhi (1869-1948),
when asked about Western civilization
You could create the same blocks in excel and plot the results as a 3D contour plot. Create a new sheet and fill a square region with the reults within the circular region. All values outside the circle set to zero.
corus
Why not a radar chart? It's not bars, but it can be data points.
