timsch
- Oct 27, 2009
- 192
I am designing a Reactor simulator for a test facility that is being planned for our manufacturing location. It will be a 36" diameter vertical vessel made of CS with flanged top and a dome cap on the bottom, with a maximum height of 15 ft. Design conditions are 175 psi @ 750F, and it will be designed to ASME SECTION VIII, DIV.1. We are looking at a shell thickness of around 1/2"
Would a shell for a vessel like this typically be made from a 36" section of pipe, or formed and welded plate? What would be the pros & cons of each option? Thanks.
