I have a 13ft diameter vessel in A-516-Gr70, which needs a thin 317 SS lining (approx 0.1 ins) in the bottom. The liner will only cover about an 8 ft wide arc and extend roughly 12" above the bottom of the vessel.
There will be nozzle penetrations into the liner. The edges of the nozzles will be coverered by welding the liner to the inner edges of the nozzles.
The outer rim of the liner will be welded to the shell.
Considering that the vessel may reach 500 degF in service, and there is a thermal expansion difference between the 317 and the shell, do I need to use any special details such as periodic plug welds, or reinforcing plugs around the nozles, to ensure that the expansion doesn't break out the very small edge welds at temperature.
Any previous experience welcomed.
David
![[ponder] [ponder] [ponder]](/data/assets/smilies/ponder.gif)
