Hello everyone,
I want to confirm regarding gate valve flange thickness and Port Diameter. I am procuring 3" ×150# Rating gate valve in accordance with API 600. End flanges needs to be in accordance with ASME B16.5. I have noticed that vendors are quoting gate valves having flange thickness of 19.5 mm including raise face, however according to ASME B16.5 the flange thickness of 3" X 150# shall be 24.3mm including raise face.
I want to confirm does the standard Allows thinner flange thickness for 3" × 150# Gate valves? Is valve having 4.8mm lesser flange thickness is acceptable?
Also I have seen many vendors quoting port diameter of 76mm instead of 77.92 mm (as per ASME B36.10 and ASME B16.5).
Please confirm does the standard allows for thinner flanges and lesser port diameter for 3" x 150# Gate valves?
Note: All vendors are quoting like this, that's why I want to confirm that does code allow this variation?
Thanks & Regards,
Wasif
Thanks & Regards,
Wasif
