I need help making a circuit that uses a momentary footpedal switch that selects between 3 sources. Starting with 1 then 2 then 3 and back to 1 with indicator LED's. Each position will close two switches leaving the other positions dropped out. The switches or transistors that being closed by the selecting switch need to be able to handle up to 14V's and up to 10 amps at any given time. any help would be appreciated. Thanks!
