Basically we have these contactors switching a bank of cartridge heaters. The heaters are balanced across the 3 phases with a maximum of 3Kw per phase. With a 15A rating these should be fine.
Our problem is the contactors are failing, they leak across some of the phases. Some leak all 3 phases while others only 1. If it was a case of 15A total, 5 per phase then underating could explain what happened. If they were sized ok, then why are they blowing.
BTW I am not working directly with this problem, I'm leaving that to the company that built the m/c. I'm just trying to figure out myself what is going wrong.
Cheers,
Speedy
