W
williaps
Guest
Hi all,
I am trying to run the custom install (Appendix B of the install guide) unbundled Intralink 3.4 M012 on an HP UX 11 server. I am to the point where I execute the install_ilink command and I receive the following error. It seems to be looking for the JRE but it shouldn't need that because this is being run from a cshell. Any thoughts?
% install_ilink DATABASE PW01D SMALL /oradata01/devl/PW01D/intralink_tmp<?:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" />
Scratch path assumed by default for UNIX (/tmp)
DO NOT REMOVE THIS WINDOW!!!
Pro/INTRALINK Data Server installation
Installation parameters:
Installation type = "DATABASE"
ORACLE_SID&n bsp; = PW01D
Database size = SMALL
Data files directory = /oradata01/devl/PW01D/intralink_tmp
Character set = UTF8
Starting ORACLE database installation:
Can not find bundled installation of Oracle. Trying to use un-bundled Oracle
Configuring Net Service Name "INTRALINK" ... /oracle/v920/devl01/bin/netca[152]: %s_jreLocation%/bin/jre: not found.
invoked from within
"ProINetHelper::addNetSvcName $DB_SID $NET_SVC_NAME"
(procedure "ProIDBCAHelper::createDatabase" line 27)
invoked from within
"ProIDBCAHelper::createDatabase $filepath"
(procedure "CreateDatabase" line 82)
invoked from within
"CreateDatabase ${ilink_dbsize} ${filepath} ${charset}"
invoked from within
"if {(${InstTarget} == "ALL") || (${InstTarget} == "DATABASE")} {
set errorCode ""
(file "/oracle/v920/devl01/ptc/dataserver/intralink/dbs/install_il ink.tcl" line 211)
invoked from within
invoked from within
invoked from within
invoked from within
set errorCode ""
