Does anyone see anything inherently wrong or ambiguous with the attached drawing per ASME Y14.5M-1994 (and/or Y14.5-2009)? I've been staring at my drawing of a part with similar features and have been battling in my head first and foremost with the Ø1.25 feature located using a positional tolerance versus locating the conical taper feature (datum B) using run out.
In use a cylindrical shaft will fit over the Ø5 feature until it bottoms out against the feature located from the virtual sharp by the .25 linear dimension and then secured using an adhesive. This shaft will slide within a tube that has a female 100 degree conical taper. The conical taper will limit the translation within the tube. This is why I've selected datum features A and B as shown. There will also be an accompanying assembly drawing where the OD of the fitted shaft will be datum feature A' and the conical feature will be datum feature B'. I want the similar features to serve as the datum features in both the component and assembly drawings.
