dsd133
- Apr 19, 2005
- 4
I am modeling a 2D truss using frame elements. The truss members are built up box members consisting of four plates and 4 connecting angles. The flange plates have 12"x18" perforations spaced at 3'-6" on center. Because of the perforations the area and stiffness vary along the chord members. I don't want to break up each chord into 2ft frames to vary the stiffness so should I compute a weighted area and stiffness. I was originally using the gross area of the section and adjusting the density to account for the perforations but feel this might be over estimating the stiffness of the truss. If I use the net area to define the sections and increase the density to account for the length that isn't perforated then I will be underestimating the stiffness and effect the longitudinal distribution of forces. So what section properties are the most appropriate to use? Has anyone dealt with this issue before?
