24 volt ethernet hub
a70duster
52
Hello all,
I am installing a Controllogix device and using a Red Lion display for the HMI. I figured out how to get the ethernet working between the two. I am looking for a ethernet hub that operates off of 24 volts and haven't found anything on the net.
Any suggestions are welcome.
Try this link, these guys are an AB Encompass partner,
Or you can try B&B Electronics, they also make a very good industrial ENet hub and switch.
Westermo have a great range of ethernet products which are hardened for the industrial environment. Highly recommended.
image.php
Sometimes I only open my mouth to swap feet...
B&B Electronics caters to the industry, with 24VDC powered switches, with integrated DIN rail mounts. They have models that are more rubust and will withstand being in a Hoffman enclosure outside.
Take a look at
I've used 24 vdc industrial grade Phoenix Contact switches in the past and have been satisfied with them.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
To all,
What we need is an industrial grade/ruggedized switch with management capabilities, and that can handle trunking VLANs.
Cisco makes the 2955 series switch, which is a 12 port fully manageable, Din rail mounted unit. It is their “industrial” offering. It works well, we have several in operation, but it is bulky, and only runs off 24VDC. Many other industrial switches have the standard 10-30 VDC range on the input power.
Does anyone know of a good managed switch for the industrial arena?
remember, always use a switch, hubs cause problems, I believe AB does not recommend using hubs anymore for any reason.
robertjo,
Take a look at Westermo's R200 and U200 switches on my previous link. I believe both have VLAN capability.
image.php
