I'm working on a site project with our state DOT. On the project, there is a pond supplying water to the fire suppression systems in the buildings. There is a 24" transfer line between a pump building and the fire pond. In that line there is a 24" gate valve. The DOT designer included the State's standard detail which shows for valves over 12", a 4" concrete bearing pad is required.
Would there be any need to anchor that valve to the pad? The detail shows no anchoring, just the valve sitting on the pad.
