emc2673
- Apr 14, 2004
- 41
Tech support, even the VAR in my area promised remarkable changes in PDM 2006. WOW it comes to no surprise that the problems and requests that I was told "would" be fixed in this release have once again reared its ugly head.
1) changing projects (with sub-projects) into other projects does not work... now what does work is that you can now select multiple files (vs. one by one)take ownership of said files and select change project but the project and sub-project folders do not migrate along with the files, so instead, the project folders are left behind and all the files are then "moved" to its new project but are now in one lump project folder. This is useless to us since some our projects are organized with many sub-projects and sub-sub-projetcs.
anybody have any suggestions or am I out of luck on this one.
Is there an option to drag and drop files/projects into other projects.?
There are other issues but this is the main one I am dealing with right now, any help or work around are welcome since I really do not want to recreate vault projects and sub-projects manually.
