2005 SP1.1 Multi-Body Part Problem
TateJ
I tried making a part & then place a single line sketch on one face. Then cut-extrude (thin) that sketch & split the part - keeping both bodies. It won't do it anymore. I did it countless times with 2004. I talked to my tech support & he told me it'd work with SP1.1 (I was on SP0.1 at the time). so, I updated to SP1.1 - same problem. I try the split feature & 6 to 8 seconds after clicking on it... Solidworks dumps on me - unhandled error. I can still do multi-body parts - so I can model each half from a seperate sketch & extrusion - but it should work the first way too.
Didn't find anything with a search here either...
Surely, I'm not the only one - or am I?
BTW - I'm going to e-mail my tech support also - but I know I'll get good advice here - probably faster.
Is it just unique to this part or does it do it with any part you try? I just did a split feature last night with no problem.
2005 sp1.1
Winxp sp1
Jason Capriotti
Smith & Nephew, Inc.
TateJ
I have just tried doing as you described and had no problems. Although I used a plain rectangle block to split.
Roger
I just tried it on another PC with the same SP & it worked fine. So there's something screwy with my installation. I think I'll re-install everything. I just want to make sure it's not a setting that I need to re-set.
... so it's not unique to this part - seems to be unique to this installation - though.
Shut down all Solidworks file. Go to tools / options/ and under system and maybe performance, Check "Software OpenGL". Now try it your part. If it works now, then your problem is video card related.
Jason Capriotti
Open GL is one of the things I tried the firat go-round with my tech support - no help there. I'm about to re-install...
Alternative to try before reinstalling faq559-507
[cheers]
Eng-Tips.com Forum Policies faq731-376
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
Tried the registry hack - didn't help.
Un-loaded & cleaned all the program files off my hard drive - then re-installed. Same thing happened with SP0.0. Installed SP1.1 - still the same. I'm stumped. I'll just work around it for a while.
tatej [idea] usfilter.com
