2003 - save as dwg problem
GREIF
19
Does any one have problems with 2003 when they save as dwg and the
blocks with linked text do not come in correctly? Example: instead of
the block saying what the file name of the part is it comes in as the
link ... "sw-file name". My var says it is an autocad problem but I do
not believe them as it works fine in 2001 & 2001+.
Gary Reif
Fox Valley Tool & Die
I just did the same thing in 2003 and the properties came through fine.
What service pack are you running?
p.s. Howdy from E.R. Wagner
[bat]You don't fight destiny, no sir... and you don't eat crackers in the bed of your future![bat]
Your VAR is FOS. It can't be an AutoCAD problem, as AutoCAD is only reading the final translated file.
We're on SP1.0. Now I'm afraid to upgrade.
What are your settings in the "Save As" options? I am saving to R14, which is our ACAD release. Maybe try that.
I have tried several things, and I can't repeat your problem. You can send me the file(s), if you like, to the address in my profile.
Are you the FV Tool in Kaukauna (the Hawaiian-named city in Wisconsin)?
If you want to send it to me, I will check it in sp2.1, but last week I could have checked in sp3 but I canceled that one due to a different very annoying issue that is scheduled to be fixed in 4.0.
Anyway, if you want, send it...
craigTAKEOUT@okswug.com
(take out the TAKEOUT)
Mr. Pickles
unfortunitly I can't send this one one because of confidentiality reasons.
I've tried adjusting every option there is one a time in many combinations with out luck.
Yep, we are the one in Kaukauna, but it's a native american name not Hawaiian, too bad if it was Hawaiian it might be a liitle warmer around here.
Gary
Can you throu together a "scratch" file that does the same thing? Just a single extrusion in a part file thrown into a drawing with a linked note. It doesn't have to be pretty, as long as the behavior repeats.
Go Neenah Rockets!
Gary,
I got your files from the SW to AutoCAD Block Attribute issue. I am currently using SW 2003sp2.1 and ACAD 2000. The Attribute thing looks to me like it has the right data strings in AutoCAD. I attached the "data" from an ACAD "List" command at the bottom...
The Attribute from SW appears as some "stairs" in AutoCAD, though. Each Attribute line of text is indented or tabbed to be starting right below the end point of the previous line, like this
Line1
Line2IsLikeThis
Line3MovesOver
NextLine
BUT, strange thing is the Preview Pane in ACAD shows the drawing as it SHOULD appear.
Command: list
Select objects: 1 found
Select objects:
BLOCK REFERENCE Layer: "0"
Space: Model space
Handle = 143
"Block1 2003"
at point, X= 1'-0" Y=0'-4 3/8" Z= 0'-0"
X scale factor 1.0000
Y scale factor 1.0000
rotation angle 0.00
Z scale factor 1.0000
ATTRIBUTE Layer: "0"
Space: Model space
Color: 7 (white) Linetype: "BYLAYER"
Handle = 144
Style = "Standard"
Font file = txt
start point, X=1'-0 1/8" Y=0'-6 3/16" Z= 0'-0"
height 0'-0 1/8"
value 001
NAME: part for testing blocks to dwg
REQ'D: 1
MATERIAL: ALUMINUM
STK SIZE: .5000 X 1.0000 X 2.0000
HT TRT: -
PART NUMBER: test block part
SCALE: 1:1
tag AutoAttr1
rotation angle 0.00
width scale factor 0.7500
obliquing angle 0.00
flags normal
generation normal
END SEQUENCE Layer: "0"
Space: Model space
Handle = 145
Mr. Pickles
Maybe I should just uninstall 2003 & reinstall to see if that cures it.
Gary
My take is that it has something to do with your block definition. Maybe try writing a new block definition from scratch.
What happens to your notes that are not in blocks?
Would I be guessing correctly that the block is used like an extended BOM balloon to identify die components in a drawing?
I am not familiar with the use of the question mark in your block definition. It turns into a number (1) when the block is finalized. Do enlighten me, please.
That did it, I created a new block & "presto" it works... must be magic.
Yep, it's like an extended bom. Some of our customers want multiple parts per sheet, so this identifies each part.
the ? is one I manually fill in, I use it for the detail number & qaunity. example part# abcd-001, abcd-002.. I repalce the ? with 001 or 002 etc. I could not find a way to link this to work showing only the -000.
Thanks for all the help
