ConstantEffort
- Dec 29, 2012
- 72
Do two 2" LWNs satisfy the Sec 8 Div 1 inspection opening requirement on a 36" ID vessel?
My vessel falls under UG-46(f)(2):
"All vessels 18 in. (450 mm) to 36 in. (900 mm), inclusive, I.D. shall have a manhole or at least two handholes or two plugged, threaded inspection openings of not less than NPS 2 (DN 50)."
I read this as, vessel shall have one of these three:
Others read it as shall
Under my interpretation, a pair of 2" LWNs with a 2" finished opening would not qualify as a threaded inspection opening of NPS2. It would also not meet UG-46(g)'s definition of a handhole (2" x 3" minimum opening).
Under others' interpretation, it is NPS 2 or larger and it is reserved as an inspection opening.
Others' argument makes sense to me, the opening on the 2" LWN (2.0in) is larger than that of a 2" 6000# coupling (1.7in), but I just cannot get my brain to read the code the way they are reading it.
1) manhole
2) two handholes
3) threaded inspection NPS 2
2) two handholes
1) have an opening not less than NPS2
2) it can be a manhole, two handholes, or a threaded inspection opening
