I have a large base plate with two columns landing on it.
The columns are laced together making up one big section.
It is essentially a moment base, but the moment is really just resisted by a couple in the columns and not in the base plate itself.
The base plate is loose, not welded to the column. Uplift is taken by brackets on the columns.
So I have uplift on one column at one end of the base plate and a downward force at the other.
The columns are six feet apart.
Do you think it is reasonable to analyze the plate using a "concentric" area around the column and a typical base plate analysis?
