Hi, I want to make a RF circuit where:
-Tranmission is done with one or two antennas(by choice)
-Reception with one (as there is only one rx path)
I use a transceiver with one Tx/Rx path. So I suppose I can split the output signal of the transceiver in two separates antennas (Pout=1/2 Pin), using a power splitter. My problem is in the reception...where only one signal can be received...I have thought a pattern with some rf switche but I am not sure how the swithes must be operated and what type of switches should I use...I sent a draw of the circuit (how I imagine it)..please correct me if something is wrong...
Thanks.....
Thanks.....
