180¦ Air Powered Hinge Assembly 4
engjeff
Automotive
My problem is the one beam has to flip on top using some sort of air or air/hydraulic a full 180° and then come back extended.
-The point of rotation is above the two beams
-when flipped the cylinder can not extend past the end of
the assembly. The point of flipping is to save length
for transport.
-The total weight of the extend moving part is 3,000#'s
distributed.
My question is what should I use for force, the beam can not slam up and down it may kill someone if it does. I have 120psi of air in that location and customer requires it be air powered.
What location should the points be to make the assembly rotate using a non cycling cylinder. As in when extended it must be flipped on top and when retracted it must be extended.
Thank you,
Jeff
For added safety you might consider a pressurize-to-release brake.
Ted
handleman, exactly, the worm drive can easily be self holding. No brakes, etc, required. You got air it runs, you don't, it stays put. Add a provision for a crank, the beam can be deployed without any external power.
Mike
I have been thinking about this day and night, what if we could get about 2500psi of hydraulic force back there. Would dual hydraulic motors work?
If so where could I get ones powerful enough yet inexpensive?
The worm gear with a crank back up how would you go about that? Tie the crank right into the gear as well?
"I have 120psi of air in that location and customer requires it be air powered. "
Cheers
Greg Locock
engjeff, I'm not a machine design guy and am possibly over my head already, but you could drive the air motor shaft if accessible or the worm shaft with a crank, or even a rachet wrench. Square drive, hex or whatever is convenient.
I believe I have exhausted my expertise on this subject.
Mike
