I am trying to connect an older 11HP EMB brand motor with 18 terminals at the motor windings. The motor was apparently used in a high voltage (440V) application with an elaborate control system with 12 contact in the motor leads. I am told the motor is two speed and dual voltage. The customer wishes to control the motor using two starters separately switched to engage high and low speed through a selector switch and timer. I have the controls worked out but need to know how the terminals on the motor must be connected to the two starters for 220V three phase power if it is possible.
