High guys... new to the sight and glad that I found you.
To the problem....
I currently have a -12vdc to ground signal that i need to trigger an ignition amplifier which can be fired 1 of 2 different ways.
1. it can be triggered if a certain resistance level of 400-1300 ohms is met between 2 pins or...
2. it can be triggered if a pin to ground contact in interupted. (break of ground)
Whichever way I go it needs to be able to fire at a rate of about 600 - 700 times per second.
Thank you in advance
Steve
To the problem....
Steve
