GasProcess
Petroleum
We have to replace 125# FF ductile iron valves ( material - A536 65-45-12 & A126 GrB ) with the existing 150# RF valves. The flange on the water filter where the valve is installed is #150 RF. There is spacer installed at present between the valve and the vessel flange.
Is it possible to fabricate a spacer flange from 150# Blind flange so that the RF of the bling flange mates with the vessel and the FF of the blind flange mates with the 125# FF flange of the valve. By using a full face gasket will a leak proof joint will be ensured?
Also any tips on gasket material selection would be greatly appriciated.
Thanks in advance.
Thanks in advance.
