genhead
- Jul 26, 2001
- 73
A 2mva 11kv generator is to be added as stand-by to an existing 11kv substation. The generator will operate in island mode when the utility supply fails. It will operate in parallel with the utility supply for peak shaving. The incoming transformer is grounded via a neutral-grounding resistor. The generator will need its own ngr when it runs in island mode (utility supply transformer is isolated). What about when paralled with the utility supply? Would the generator ngr have to be disconnected, or can both ngr remain connected?
