Jacob Noble
Materials
I did a tensile test on 2 samples of 1018 carbon steel not heat treated. The samples were from the same order, tested one after the other, no machine settings changed (only re balanced), yet the samples have completely different results from the test.
Densities were also later calculated with both samples having similar densities, within error.
Attached is the graph of both samples (stress vs strain) and some calculations from it.
I would like help in determining how the results are so different when they are supposed to be the same material.
