subsearobot
- Jan 19, 2007
- 217
Hi!
I've got a compression spring that is failing at around 100k cycles. I am not all that experienced with spring design nuances...
I've tested 16 springs, of them, 3 have failed. One was broken in two places near the center when removed from the housing and inspected. the other 2 appeared bent (no longer cylindrical). when I tugged on them, they broke near the middle. felt like a brittle failure.
material is 17-7, heat treated.
Operating between about 40% and 80% compression
~1HZ
the (design) numbers:
load 1:2.95lb at 1.195" (spring length, not deflection)
load 2:6lbs at .88"
wire diam:.028"
coil OD:.180"
Is this design pushing a boundary that I am oblivious to?
Please comment!
~1HZ
load 2:6lbs at .88"
wire diam:.028"
coil OD:.180"
Please comment!
