i would be grateful if you can help meon below case:
According to API 610, for parallel operation 10% head rise to shutoff shall be considered. We have ordered a pump last year which showed smoothed curve with exactly 10% head rise from rated point to shutoff. However, one week ago on performance test the head rise to shutoff was 4%. Vendor claim that since according to API tolerance table (Table 16 of ed. 11) shutoff can be decreased to -5% and also rated point can be increased +3% so it is acceptable. There is a note also in API table in which stated that if a rising head flow curve is specified (see 6.1.11), the negative tolerance specified here shall be allowed only if the test curve still shows a rising characteristic. My question is that whether it is necessary to pump follow 10% head rise on test or not.
thanks
