TroyD
- Jan 28, 2011
- 98
I have a rural client constructing an addition to his mid-1980s residence. The homeowner used a backhoe to excavate for the perimeter foundations and dug 2 feet too deep in some areas. The building official is asking for a fix/sketch from a licensed engineer. (Frost depth is 42 inches). It is generally agreed to backfill with 1.5" washed rock, rather than re-use the excavated material. There is no soils investigation, but the material on-site is best described as Silt Loam. I have observed this 1.5" washed rock used as pipe bedding in soft/wet areas on municipal utility projects. Are there general guidelines for using this material as a base for a residential footing and foundation wall? Does it need to be placed/plate compacted in specific lifts? I think I will require the bedding width oversized 1 foot minimum each side of the footing. The addition is just a split level basement wall, with a floor and roof above...not a significant axial load.
And additional input is appreciated.
