Hi...
I'm an auto tech but not a electric motor tech...
I joined the forum to see if I could get a bit of help...
I have a 1.5 hp Peerless motor...
It is on a 150 gallon compressor...
I bought the compressor a while back from an old man, He said both the motor and compressor
had be reconditioned...
The other day I was working in the garage the compressor tried to start but the motor just made humming noise...
It just hums on start up. It will run when I help it a bit by hand...
I replace the capacitor does the same thing no change...
I took it to a motor service place and was told the winding insulation looked bad...
I brought is home and took a close look at it and the motor looked like it never been opened...
So I took it apart and the windings look brand new the paint is not even faded...
The switch and contacts look good...
I don't know the correct name for the part right behind the switch on the armature shaft.
But it sure looks like a governor to me. It has two springs and it looks like it
expands with centrifugal force... I checked it and it seems to be working normal...
When I push inward by hand it slides on the shaft very smooth the section where the springs
are connected expands smooth also...
Below are some pictures I took...
Any help with checks I can make with Ohm meter on this problem will be very appreciate ...Thanks...
Link
Link
Link
Link
Link
Link
Link
Link
Link
Link
Link
Link
