1/12 HP AC Motor
martylosch
1
I have a requirement to replace existing motors with the following spec: Epoxy coated, 1/12th hp (60 watt), single phase, 115, 2.0 A, 60 Hz, 3000 RPM, TEFC. Any suggestions on where to purchase (or manufactures) - Thanks
60hz 3000rpm?
Are you sure it isn't either 50hz/3000rpm or 60hz/3600rpm?
Epoxy coated may need some clarification. But I believe some of the manufacturers are using vpi on their random wounds now. (used to be all varnish). Maybe it will be available off-the-shelf as part of a severe-duty IEEE841 option.
Nothing else should be a problem. I would enlist the help of any local distributor to give you options.
Why do you want to specificallyy identify epoxy? If you are just concerned about resistance to chemical/moisture intrusion, then maybe you should formulate your spec a little differently.
