Мaterial in material (put in material in material)
  • Thread starter Thread starter mariyanc
  • Start date Start date
M
mariyanc
Guest
How can I without using mate
this should not happen in the photo
material not to enter the material?
SW will allow you to put objects inside one another/ clash objects (they call it interference). The ability to detect collisions can be done using the move command in the assembly, but it's only on during that particular move, as it's resource-heavy. Is there a reason you don't want to use a mate? WHat are you trying to achive? An animation? If you have the motion simulation packages you could simulate the movement?
