100 Mvar shunt reactor total power losses
osizer
EU
Hello everyone,
What are the estimated total power losses of currently produced 220 kV 100 Mvar shunt reactors?
Information about total power losses of a shunt reactor with similar power or at a different voltage (e.g., 110 or 400) will also be useful.
Hello osizer,
our standard 230 kV, 100 Mvar shunt reactors (three-phase units, gapped-core desing, ONAN cooling) have about 175 kW total losses @50 Hz.
For 60 Hz units, you have slightly higher core losses per unit of weight, but these are generally compensated by the reduced core weight, leading to comparable total losses.
I would say that, as long as you do not have strict footprint, weight or transportation constraints, a quality factor (rated power / losses) of q = 500 ÷ 600 is a reasonable expectation for 100 Mvar units. Three-phase units could potentially reach values closer to 600, whereas single-phase shunt reactor banks might be closer to 500.
We have a new ABB 115kV 100MVAR and it's ONAF losses are about 220kW, which I believe includes 12 0.55kW/0.5PF 400V fans, if that's at all helpful. It's not assembled yet, but that's what the nameplate states.
